Prime prbs
Dinuth
After i run my buggy few minutes and when i fill my nitro tank with nitro when i try to prime it the fuel goes to carb and at the same time all the fuel come back to the tank. And i can see fuel coming from the carb and like its pushing fule to the tank again.
It's kind of deturing to someone when they read someone else's post and they have to try and decipher what's being said and or asked,...you will get faster/more responses to your post's if they are easily understandable,
You don't have to shut the engine off to fuel, sounds like your lsn is lean and or there is an air leak at either one of the fuel lines, base of the carb, fuel tank lid, all the exaust connections, check all of these areas, also find out the factory needle adjustments for your engine
Okay. I will check for any air leaks. And will update you as soon as possible. And my next messages will be easy to understand. Sorry about that. Thanks
If I'm understanding you correctly, that's a normal condition. As long as you've primed enough fuel into the engine to fire it, there shouldn't be a problem, The engine will draw fuel as needed.
If your engine doesn't draw fuel then you could have an air leak or a gummed up carb.
When i start it firts fuel goes to carb when i prime it. But after 4 or 5 minutes runs the engline stops and push the fuel in the carb line and also i can see bubbles in that hose
