MightyMantis
Hi all,
I have an Axial .28 Spec 1 engine with a Axial pullstarter and i have a problem with my pullstarters getting stuck. I can't seem to run for more then two weekends before it gets stuck and it wont go back in all the way. You can hear the grinding of dirt when you manually try to wind it back in. I've tried to clean it by taking it of my truggy and spraying WD40 into the pullstarter and hoping all the dirt would get flushed out.
I think the main reason it collects all this dirt is because it seems dirt gets in between the pullstarter and the backplate. Is there anyway to prevent this from happening? I was thinking of adding somesort of silicone based ring in between the backplate and the pullstarter to stop dirt from collecting there...
I'm sick of fixing the pullstarters, and if I can't get this solves I might have to switch to a rotostart which I dont really want to because you have to drag it around with you all the time ...
Any thoughts?
Any thoughts?
