please help me
Mount, pipe and header for starters. I'm taking it that your talking about a sirio .27. Then you'll need to upgrade everything from the center shafts, diffs and driveshafts. Basically everything in the driveline.
throttle linkage will need to be modified
Yeah adb is right. I think you'll need a slightly longer rod from the bellcrank to the carb. If you want big power then the s27 is good but a picco 26 is pretty much a drop in with an ofna mount. Somebody correct me if I'm wrong, the picco will bolt to your stock exhaust, but the s27 has a big block exhaust port. Neither one is a big block though. Of course that's only if you're planning on using the sirio, you failed to mention the brand of 27 you want to use.
