pins keep breakin on tranny drive shaft???
That is a weak point in the transmission. The pin is breaking off between the shaft and the gear hub right? If so, you can loosen the slipper clutch up. There is also a mod using FOC pins cut and threaded on both sides of the gear instead of one.
