Pilot shaft?
mattyk6
RCTalk Champion
What is a pilot shaft?
I'm looking for an engine to go into a Storm. Picked up a Storm rolling chassis and now I need an engine for it.
Thanks,
Matt
pilot shaft
standard shaft
I was told to get a pilot shaft for my storm. Is that correct? What does the pilot do that the non-pilot doesn't do? And vice-versa. Why the difference in shafts? And is the threads the only difference?
Thanks,
Matt
yes u want you pilot shaft, and why they have 2 i dont know, but i dont think I've seen a standard shaft .21 before (personally)
Thanks,
Matt
The only difference is the shaft itself. The threads are the same. You can use an adapter if your RC requires a pilot shaft and your engine doesn't have one. If you engine has a pilot shaft and it doesn't fit on your RC because of the unneed shaft, some people are known to cut the pilot part of the shaft off. I don't suggest that.
Typically, you want to buy the proper pilot / non-pilot engine that your RC requires.
-RobH
So, pilot just refers to the part of the shaft that has no threads?
Thanks,
Matt
