Peak Performance Diablo .28
jstoeckel
Binghamton
I plan on puttin the diablo .28 in my bb conversion t-maxx i was wondering what kind of flywheel and clutch i should put on it?
Depends. Do you want to stick with the stock style 32 pitch gearing or do you want to step up to the 1/8th scale setup with the more heavy duty stuff?
I'm getting steel gears in the trransmition(forward only) as well as in the diff so if by getting steel gears I'm upgrading to 1/8 then yes thats what i want..i would like to just keep the clutch bell 18t and the spur someweres aroun 72...Can i use a clutch bell and flywheel for a .21 engine cause it says that the engine has the same mounting and size of a .21....thanks-joe
you will need Srobe slipper clutch and 52t ofna and 15t clutch bell if you want to be in 1/8 set up ....or you will be on 1/10 setup
ohhh by the way the clutch too you will to change it
