Ok I don't own a LST or LST2 but I do own a Muggy form Team Losi,
Here is my question. A friend purchased the Muggy and I watched the Muggy perform I loved it so much I got one a week later.
After about week of off and on running the one way bearing inside the engine kept slipping, You would stick the rotorstart in the back of the engine and the engine won't turn over. We called Horizon Hobby tech support on the problem, they told us that during break in you run the muggy rich and the oil in the engine was causing the one way bearing to slip, take it out and clean it with some contact cleaner and re-install it.
Which we did, yes the one way bearing was catching again, but I took my Muggy out and ran it within a few minutes the bearing frozon on the shaft.
My friend now not even sure if you wants to run his till we get some replacement one way bearings.
Any other sugguestion on what we might do as far as cleaning them.
Does anyone else have this problem? Or are we going to have to stock up on the one way bearing?
Thanks for any help you can give us......
