One great Failsafe tip!
Candyman
'Cuse is in the house!
Syracuse, NY
OK, here's the story. I was out running my Sav last night. Trying to get that damn 4.6 tuned and working on the shift point. I was banging around the front yard. Turned and went WOT for a second down the side of the property. Let off the throttle and....nothing. Truck was heading full speed for the fence at the end of the yard. Luckily it's an older springy metal fence that's overgrown with a bunch of big leaf plants. So when it hit, it just bounced back and flipped. I ran after it while it shut itself down. I flipped it back over when I got to it. I turned the wheel on the radio and the wheels turned just a little. So I figured dead batteries. But then it dawned on me. I have an OFNA failsafe AND a throttle return spring in it. What the hell?
So I went down to look at it after work today. I turned on the truck and radio and all seemed ok. I turned off the transmitter and the servo moved to full throttle. I turned off the car and the TRS put things back to idle. So, if you're following, you know what happened.
Yes, I set the failsafe to go to full brake BEFORE I realized the throttle servo needed to be reversed on the radio. So when I reversed it on the radio, that meant the failsafe was programmed to go to WOT when the batteries dumped. So, the moral? Set your failsafe LAST! Now I have to go see if the engine is damaged.
i did the same thing ...when i had my t-maxx ... the batt pack in my reciver died and i only could lucky control the sterring.... so i had to caitch the truck with my hands... and i almost broke my fingers... the very nest day i got a fall safe.... thanks curtis ' allen' daryl
Yup did that once too. I was lucky that I double check it before went out. Else I would have hurt 3 stupid kids that came out of nowhere.
My failsafe has worked great til I went to put it on my new pride of the fleet- THE LSP. Installed the radio gear made sure everything for my JR was working proper and then installed the failsafe--set-it and then went to run it the next day but first I double checked everthing...and wham the first check it went to full throttle -now I'm confused-tried it again and it worked right so it needless to say is not on the LSP and I asked a few buddies and they all said that my digital ultra torque sevo's take too much juice to run it?? Well I did have one run away before I think I found the real culpret--my fancy aluminum antenna holder mounted to the aluminum chassis = alot of glitches but I am not going to take the chance of the failsafe so it will stay on my Maxx. :-)
sometimes my failsafe will reveres itself!! ill turn it on one time and it will go to wot il like wtf but later after tuning it off and comming back it will be set to full brake.. its brand new so i dont know whats up with it..
hey, does anyone have a failsafe that they would like to sell or trade me?
-Pat (redhatman)
