mustangwagz
Hey folks, first losi I've EVER owned. got it free without the body. cleaned out entire motor and pull start mechanism and OWB, motor DOES RUN if i put a few drops of fuel into the carb throat. although, will not pull fuel through the dang hose. The motor is a "Mach .15"
The fuel filter in tank DOES seem to be clean, cuz i can prime the motor (by pinching the line coming from exhaust and opening & closing the fuel lid a few times) fires up, runs for a few, then dies n i have to restart my process. i did clean carb out a little bit, i removed both high and low mixture scews, and used compressed air to blow though the holes, along with nipple (haha, nipple..) that the fuel line attatch's to and then watched for fuel to come though while priming.
Not sure if i got the H&L screws set improperly or if there's an issue with the forced air that should be coming into tank via the exhaust? Anyone got any ideas? Thanks folks, hope someone can help!!!!!!!
-WagZ-
-WagZ-
