Ok what the hell is goin on
Domination
Ok well i picked up a 1500mah 7.2v pack from my LHS along with a charger one of the 15-30 min ones too but the battery isnt charged all the way when the charger says it is it goes dead after the motor turns over like 3-4 times is the battery dead or am i chargeing on the wrong option I'm chargeing on the 3-5 cell they have a like 6-12 or suttin like that and i tried that too but it was even worse
aight thats what i was thinkin I'm gunna try one more time to charge it then ill bring it back
ok it still aint workin and I'm pissed alls i want to do is break in my new maxx i just f*ckin punched a whole in the wall so i have a question first should i be chrgin it on 4-5 cell (1 amp) or 6-7 cell (4 amps) for when i get another battery tomarra and my second question how do you fix a whole in sheet rock
Ok well i brought the pack to my LHS and had the guy there try it in his ez start and it worked so i was like aight ill go home and tell you how it goes ill check everything over turns out that the lil friggen yellow fround wire was f*cked up so i fixed it not it turns over no prob so i got all stressed and put a hole in my wall for nothin
Sounds like a hard lesson learned. As for the 7.2V battery, that is typically a six cell pack. You may want to consider charging it on the 6-7 cell setting.
As for the sheetrock repair, go to Lowe's or Home Depot. They cell patch kits and can give you directions on how to make the repair.
