ok i got a servo question
Nealy587
RCTalk Racer
ok so along with a slipper issue I've been having a throttle servo issue.. now and then it will go phyco and bounce back and forth from nothing to brake, then ill be moving the trigger and wont do anything. just every now and then for a minute. the truck will be no more than 20 feet from me. my antanna on the radio and truck are up and batteries charged. could it be just the servo is going bad?
I had the same problems with mine. My problem was that I had the screws from the servo to the throttle arms too tight. It was causing the servo to not be able to move freely. Check screws to make sure they aren't too tight, if that doesn't solve it then replace servo. Could also be radio interference, do you always run in the location your having problems with?
do both of them glitch or just the throttle
it will glitch back and forth or wont do anything for like 2 seconds.
---------- Post added at 7:50 AM ---------- Previous post was at 7:49 AM ----------
ill try loosening it a lil and see if that helps today. and it happens everywhere.
