I'd also consider your clutch setup. You should consider upgrading your clutch (or tuning it for your track). It is an Industry standard to put heavy springs on factory kits. If you are on a loose track fishtailing out of corners preventing you to line up your jump, your springs are too tight. Also recommend a heavier flywheel to slow down the
initial spool up of the engine for the first 2 to 3 feet. This is the most critical part. If your track is super blue grooved surface with a weak clutch setup. then you engine will feel like it is bogging down, this is when you need to spring up the clutch and lighten the flywheel.
