ofna picco .26 max Big block
GrudgE
Cressona, PA
Ok what is needed to install this engine in my revo. and what parts will need to be upgraded.
u will need a ofna 26 revo mount, i would get a better pipe than a stock blue one, u should either get aluminum cups in the diffs, or put thick oil in them like 30,000, and get a foward only conversion.
I already have the FOC, and will be using a Trinity pipe. I will get the thicker diff oil also, I was planning on getting the ofna mount my lhs has it for 20 bucks.
yeah thats normal for the mount and while your there i would just save a trip and pick up a higher toothed clutchbell
if you have problems with drive shafts breaking skyline hobbies on ebay has some n ice one for only 10 bucks a set. just take the set screws out and lock tight them before u use them.
The Ofna mount will only work with a 16T CB and 36 tooth spur.
iI's got limited adjustment, I recommend the New Era mount if in the future you want to gear higher on the CB without running a teeeeny tiny spur.
I'm running 16/40 from robinson racing with that mount. Also with a dremmel you can drill out material from the adjustment screw for my spur and clutch combs. But the new era mount is a Plus. But the ofna is 17 at my lhs.
