Tower say they will be available mid to late November...
SPECS:
Displacement: 0.298 cu in (5.0cc)
Bore: 0.728" (18.5mm)
Stroke: 0.717" (18.2mm)
Practical RPM: 4,000-36,000
Power Output: 3.0 ps/28,000 RPM
Weight: 12.7oz (360g)
Crankshaft Size: 1/4-28
Factory Needle Valve Setting: 2-3/4 turns open from fully closed
Distance Between Mounting Holes Same Side: 0.83" (21mm)
Distance Between Mounting Holes Opposite Side: 1.4" (37mm)
Distance Between Mounting Holes Diagonal: 2.3" (59mm)
Height Bottom of Mounting Ears to Top of Cylinder Head: 3.8" (97.7mm)
Width of Mounting Ears: 1.8" (45mm)
Width of Crankcase Below Mounting Ears: 1.2" (30.8mm)
Distance from Front Bearing to End of Crankshaft: 1.2" (29.5mm)
Distance from Center of Engine to Front Bearing: 1.7" (44mm)
Distance from Center of Engine to Backplate: 0.85" (21.6mm)
http://www2.towerhobbies.com/cgi-bin/wti0091p?&C=GCT&V=OSM
SPECS:
