O.S. .18TM owner. Can you...
MyJeep
If anyone here have a O.S. .18 TM. Can you please check the HSN for me? I bought mine 3 weeks ago and have no time to put it in.
I am going to put it in this weekend. I found out that the HSN only 2 turns out (out of the box). Just want to make sure before I crank it up.
I didn't check it when I first got it, I just cranked it in and then backed it out 3 turns as per the manual. It fired up with no problems. I think it took half a turn before I ever got into second gear but that was because of the wide ratio gears in the tranny.
Thanks! I will try 3 turns out.
The setting on the mill is totally wrong when it was out of box.
yeah, the manual said standard setting should be flush and then half turn closed....
i just ran it like it was outta the box, and it runs sooo nice
