Not tuned right?
aj200415
I have a megatech neo .16 engine on a buggy. The needles are set to the factory settings(2 1/2 turns out) wich should be pretty rich. I start it up, let it run for about min, min and a half, and give it one 3/4 throttle run in my small drive way and come back. Its red hot when i shut it off! I checked for air leaks in engine and then in tank, and ended up taking the primer out. It didnt help at all.
I'm using 20 % eliminater fuel.
wat temps are u getting ??? anything between 210-230 f will b fine any hotter just richten her up a bit.
I've personally never heard of that fuel
well i dont know the temps. cause i dont have a temp gun. I know its too hot and it should not get that hot that quick!
Never used Elinator fuel. Is it made for cars or airplanes? Have you done the water drop test?
Drop a few drops on the top of the head. I should sizzle for about 4-6 seconds.If it vaporizes right when it tuoches the head its way too hot.
Let us know
Let us know
yep, it vaporizes in like 2-3 sec.
Not familiar with megatech mills. Does it have one or two needles?
if i richen it any, it boggs and wont stay running.
2 needles, high and low and they are both set to factory.
both are set to factory, 2 1/2 turns out. But i had to lean the high out a 1/4 turn to keep it from bogging and dieing when i hit the throttle.
Factory settings are typically rediculously rich to cover the company's ass legally. If they gave you an engine that was too lean, and you blew it up without adjusting anything, you could blame them. Since you don't want to cough up the $20.00 for a temp. gauge, keep this in mind:
Water boils at 212 degrees F. So spit should sizzle within a couple seconds. Better yet, would be an eye dropper full of water, since it puts out water drops instead of bubbly saliva. Use the high speed needle to get that in range. The problem is that any temperature over 212 will get the job done (you could be at 300 and not know -- that is where the gauge comes in handy).
Once you have done that, pinch and hold the fuel line closed to make sure that the engine dies within 3-5 seconds. Lean to make it die sooner, richen to make it die later. Make sure you get this right. If this needle is too rich, you could be running your high speed needle too lean (starving your engine for lubrication) without knowing it.
After all thats set get your idle gap set to factory, and then adjust to make it as high as possible without engaging the clutch (without making the car move).
Once all that is done, re-check everything, since a change to one needle affects the others. Keep playing with it, until temps are in range (boiling spit), the engine dies in the right ammount of time, the idle is set properly and you should see smoke from low-mid rpms when accelerating.
EDIT: While you do need to make small adjustments (1/12th turn at a time -- 1 hour on a clock), don't be afraid to be well away from factory settings. The weather in Japan or Italy or wherever your engine was built is probably different from where you are at. You are making adjustments for YOUR situation, don't worry about what works right for anyone else.
There is no ballpark settings that people can recommend, you just need to play with it until you get it right. Unless of course, you can do the math to determine your altitude, barometric pressure, temperature, humidity, glow plug brand and type, fuel brand, type, and percentage, and manufacturing tolerances of your engine/carb/plug, clutch setup, body openings, air filter oil, etc. If you can pull that off, NASA may be hiring.
got the low tuned, but i have to lean the high to a certain pt. to keep it from dying when I take glow ignitor off/give it gas, but then it is running hot again.
Maybe what you consider hot isn't as bad as you think. Since your engine should be at least 20-40 degrees hotter than what is required to boil water maybe what you consider hot is actually normal or even too cool.
My Opinion Is If You Are Going To Play With Nitro Cars And Stay With This For Awhile I Would BuY A Good Temp Gauge First
This Way You Are Taking All Of The Guess Work Out And You Can Start Tuning By Temps Correctly
30.00 To 50.00 For A Temp Gun Is Cheaper Than A New Engine And Less Headaches
