I recently got a tMaxx off ebay, engine was dead so I fitted a Pico .26, just about finished running it in now, but its not shifting to second. Its defiantly revving hard enough and the slippers tightened down, I've opened the rubber bung and turned the grub hex anti clock wise to no effect. When I first looked the hex was screwed all the way in and i was able to hold the spur with the cut out visible and rotate the stub shaft poking out the front of the box to find the hex, now when I rotate the shaft the inner section the grub hex bit doses not rotate.
Is it time to strip the box and look for damage?
