noobie here needing help!
dons18w
t maxx classic 2.5 that will not turn over, the easy start not the 2.5? have a tried a new motor not hooked up and have the same results. Quarter jerk the gear other than that giggle no movement? Have tried a new controler and battery full of charge? I'm totally lost on this one ne ideas?:angry::whhooo:
i have 2 good motors one in the truck and another 1 hanging on the side?
if you've tried two motors and get the same result on both with the same ez start system then it's gotta be the ez start. have you checked to see if your one way bearing in the back plate is alright? maybe some how it got reversed and the electric motor is trying to turn but being stopped because of the bearing. Also, if you have a pull start that you can try out on the motor(s) just to be sure that would be a good idea to throw it on and give it a pull. If the bearing is alright, then there may be a gear that isn't sitting right in the ez start itself. open it up and take a look. Last, but maybe should be first, is give traxxas customer service a call and let them know what's happening. They may have some additional advice on some things to trouble shoot. They're always very helpful...
hey guys thanks!!!!nit was the easy start gears.....its up and running now!
