This was playing up last night, stalled out of the blue under brakes, fired up again no probs, drove out about 10m & cut out again, kept doing it.
Started & idled fine but would cut out both under brakes & under power.
Was getting pretty hot idling as well.
Messed with the tune - didn't help.
Replace the glow plug - same.
Hosed out the carb - same
Check the lines were clear - same
removed failsafe - same
Cracked the shits & went home.
Pulled it down this morning, pulled the motor apart - all good, resealed it real well.
Stripped the carb, resealed that including some grease on all the O-rings
Cleaned up the pipe & header, checked for cracks/leaks, refitted & resealed.
Cleaned out the fuel tank, blew compressed air through everything.
Put it all back together & fitted the new motor save filter that arrived yesterday arvo.
Fresh tank of juice, needles reset to factory.
Problem solvered, all good, retuned it & running well.
Still dunno what was causing it, had to have been a fuel supply issue, but I dunno why - nothing stood out as being the cause, but whatever it was cleaning & resealing everything seems to have fixed it.
I hate not knowing what the problem was - if it happens again I'm none the wiser as to where to look first.
---------- Post added at 10:10 PM ---------- Previous post was at 10:01 PM ----------
Pics (minus the motor saver filter I fitted this morning):
