no reverse/help
gmann46
2.5 tranny foward 2 gears fine but won't go into reverse when i switch it it just spins not sure if it is even going in or something else could be the problem
You can take the cover off the throttle/brake box, shift between forward and reverse, make sure the servo is working correctly. If it looks like the servo is working correctly, you may have to crack open the tranny and see if there is a broken part.
reverse gets stripped out pretty commonly if you use it too much... to Fast-hard. **(woops)**
I'm so much happier after doing the Forward Only Conversion to the Revo that I now refuse to use reverse when driving my Subaru...
AJ - Keep skipping... it keeps the kangaroos away.
