Shocks - you'll need something that is easily adjustable. You need 90mm in the front, 100 for the rear. The front shocks you'll need to open up and make them compressed with the fuel tube trick, to lower the front a bit about 10-15mm.
I know people hate on Integy, but I have always thought their shocks are good. These models have two different springs, and are easily adjusted, and don't leak at all -
https://www.integy.com/st_prod.html?p_prodid=34126&p_catid=109 and
https://www.integy.com/st_prod.html?p_prodid=34135&p_catid=109
For toe-in, you're gonna get a lot of different views. I think the stock Slash toe in is 3.5 (or 2.5) degrees - it's pretty extreme. It's great for the first 60 ft and staying straight, but it kills the top end. Some like 0 degree, but that's definitely harder to drive. IMO the best is 1 degree arms made by STRC -
https://www.amainhobbies.com/st-rac...akIu8Fl-jESI1MJhc_FvEenDdaao0A6EaAsRwEALw_wcB
These also give you a tiny bit of extra weight over the axles where you need it.
When you adjust, it's a matter of getting it to go straight when the tires shake lose. I was going hard right, and you can see why - my right tire is ballooning while the left is flat -
Wheelie bar wheel on the right is on the ground, left is up. So I need to stiffen up the right shock - or soften the left, since both shocks are set very stiff.
I use 15wt oil front and 50wt in the rear. There are a lot of varying opinions on that too. Prevailing theory is to use lighter in the front, heavier in the rear.
