No power in my savage flux hp electric
Buddah
Hey guys just trying to get some help I blew my drive gear in my savage flux hp electric. I replaced it with a stock one and tighten everything including the slipper clutch and now there is just no power can not do back flips or wheelies. Please help.
Thank you
Is it making any horrible noises? Or sounds like it always has should when running? Meaning>> are your gears meshed correct after putting it back together?
What did you replace, the pinion (one on motor shaft)? If so, did you use loctite to prevent it from slipping on shaft?
Hey guys. Everything sounds good everything is meshed up right I put loctite on pinion on motor shaft tighten slipper clutch and backed it of half a turn. Took it for a run and it still the same result. Was talking to a friend and he thinks it's the gears in the dif might be cracked. Just haven't had time to pull it apart what you guys think about that?
Thanks for your advice.
