no power in my batteri!!!!!!???????????????
isak
sweden
Hello!
I am having problems with my 6n-3600 ni-mh 7,2 volt ez-starter batteri.
I charge the pack untill it is fully charged. I start my revo and twenty minutes
later my ez-start is dead, it barely turns the engine at all. And i can't start my revo3.3. PLEASE! help me, i really need your help...:):bow:
You sure that it was fully charged? How long did you leave it on charge?:surrender
Batteries do discharge with that much use in a day especially if you are starting it more than 20 times,easy start does drain the battery pretty quick also .
In that 20 minutes, are you using the battery or is it just fading on it's own? If that's the case, it may not be fully charged. Are you using a peak charger to make sure it's fully charged?
How old are the batteries? Have they ever been significantly overcharged? Have they sat for a long period of time with no charge on them? How many times have they been charged? Just asking because batteries will lose their charge capacity as they get older. If they're old, may be time for a new pack.
I bet that they are nicad batteries. NiCad batteried will build a memory and they are not available in the higher MaH's. Upgrade to NiMh batteries and a peak detection charger and leave the old ones behind.
Personally, I use a Venom 3600 MaH, NiMh, and a piranah charger.
