I have a new Team Associated mini MGT 3.0.
Just broken in with 5 tanks.
I'm having a problem that is baffling me - and probably doing much damage to the .18 engine. FIrst of all, and I'm not sure if this is connected: I've noticed a high speed bog, which I now know is due to most likely a lean condition for the HSN. I will fix this before next run.
The problem rarely is after a high speed run, usually after switching to high gear the truck starts revving uncontrollably, without moving. Almost like its in neutral and decided to go full throttle. I thought at first its the crappy AM radio, so i replaced it with a 2.4ghz model, which doesn't seem to glitch at all like the AM one. This had no effect. I had figured the glitching pulled transmission servo halfway, putting it out of any gear, and held the throttle open. HOwever after today's run with teh 2.4Ghz radio it still happened. I ran back to the truck to see the throttle in its off state.
It might be because of air leaks in the motor...but why is it the truck doesn't move?! its in gear, but the engine just revs like hell. Once I hastily shut it off, wait 10 seconds, restart, everything is good again (when its cooled down???).
Any idea what this could be, and how to remedy????
(I've been running it around 2-5C temperatures lately.)
Thanks in advance
Thanks in advance
