HPI pro 12r XS
Hi,
This engine is a really fast and smooth running engine.
lots of rev`s, lot of power.
I`ve installed it in my serpent impact and i am breaking it in now, this engine is very nicely build and it`s definitly a novarossi engine.
It is not an easy to tune engine. It`s a 3 needle carb. so you really have to take you`re time tuning the low to mid range, and mid to high range needle settings, you got to have a lot of experience in order to make this engine run smooth at the right temp.
will post more info later!
happy racing......
Hi,
performed break-in and engine is running at (almost) full potential now.
this is a very nice and fast .12 racing engine!
absolutely worth you`re money (i paid usd125 at meganitro.com)
not sure about the 1,35 hp, maybe this is what you get when running it on a bench with prop. and 30% nitro, just before the engine explodes.
anyway, it`s has far more power than many 'standard' .15 engines and is easy to maintain and run.
my 'first start' break in settings:
high speed needle: 6 3/4 turns ccw (manual says 6 1/4)
mid/mxture needle: 2,5 turns ccw (manual says 1 - 1 1/2 preset)
low speed needle : 4 1/4 turns ccw (manual says 4)
tornado fuel with 16% nitro and 19% caster oil.
the preset setting on the engine i received where wrong, and not according to manual, please check this before starting.
i ran the first 3 tanks at this (very very rich) setting (you will be ok breaking in at manual`s settings) and turned in highspeed needle approx. 20 deg. every following tank. stayed at low to mid speeds/rev`s. with a short full trottle every now and then..
ran about 20 tank (75ccm) of fuel this way.
after break in : (very cold outside and moisty)
high speed : about 4 still slightly on the 'rich' side
mid : about 1 3/4
low : about 3 3/4
could not make runs above 30mtrs (1 to 2 sec`s) i choose a
rich setting for this engine. please don`t use this settings as a guideline, for it may vary under weather influences and nitro fuel used, and i rather have my engines run longer than faster, so i always tune them a bit rich when touring on a parking lot.
again, this is a very fast engine at low pricing!
have fun....
Remco
