Nitro Power Kleen??
diglife2004
Both of my engines are filthy due to the fact that my exhaust manifold screws got loose. Well...i think i've fixed that with loctite but i was reading about Nitro Power Kleen. Is this stuff any good? Anyone use it?
Yes it works pretty good, you will use a can very fast if your not careful with it..LOL You could also buy denatured alcohol as well and use it in a spray bottle, works just as good I think and is quite cheaper.
I clean my cars with WD-40 (or some other kind of spray lube) and compressed air. I just soak the whole chassis down to loosen the dirt and grime and let it set for a minute. Then I fire up my air compressor and use a blow nozzle to cut it off. This way there's no water used that could hurt your radio gear. I once used Greased Lightening and ruined the anodized purple on my RS4 chassis. Make sure to stay away from the alkaline based cleaners. I like spray lube and high pressure air
