Nitro Fuel?
yveschew
hi, its that any problem if i change the different brand nitro fuel? thanks
Not at all, you will likely have to retune for the new fuel. If at all possible keep the same nitro % that will make the switch easier.
+1 now when you switch and keep the same percentage post the results of what you see without retuning, and then the results after retuning.
I have had to retune, from using 30% O'Donnell's to Sidewinder Canadian Team Blend 30%, about 2 turns leaner on but LSN and HSN
