Hello,
I think i bought a junk evader (used). I cannot/barely :devious: make it start. I have to hold the throttle really high, so it will not die, but it will go everywhere. When i tune down the throttle, the car die. I really really have hard time to start the engine again. I found out the the flywhhel is moving sideway :devious: . Is it a broken engine?? I have already re-connected (make it longer) pressure line and put a new O-RING for the gas tank, & new glow plug, and all still the same. I also put the TMAXX exhaust pipe as i think the stock one is not generating enough pressure.
If i need to replace the gas tank, which one i should get?
If I need to replace the engine, what engine will fit, i am cool with a .12 for budget? As, my friend need to modify a OS 0.12 in order to fit into a TMAXX, and i do not want to do the same thing?
Anyone knows the warranty info?
I took out the head, and found scratch inside the engine? IS it normal?
can you please really help? I have been fixing it 3 weeks already!!!
Cheers
Drew
Cheers
Drew
