nitro car tuners in logan queensland
spaos
Queensland, Australia
hey guys i am just trying to find out if anyone knows of someone who tunes nitro cars in Logan, Queensland, Australia if someone could help it would be greatly appreciated
better to just do it yourself bc your tune is hoimg to change from day to day anyways just do some reading about tuning and what knot its nit that hard to do
Just stay patient and keep at it. I got frustrated at first but after a while you can just tell by the way it is running what needs to be adjusted by the way it sounds and the way that it feels.
if its at factory setting try leaning it out a little bit it may be to rich. to much fuel is just as bad as to little
---------- Post added at 11:07 PM ---------- Previous post was at 11:07 PM ----------
does the motor start at all?
yes it does start i have had it running long enough to go through 2 and a half tanks but that is it
it starts for about 5 seconds and spews heaps of fuel out of the exhaust
yea.. turn the HSN a quarter turn in and give it a try. if you are spitting that much fuel you are rich. Keep doing passes until you don't notice any more performance improvements or its bogging down at high RPMs. If its bogging at high RPMs you went too lean. Then move to your LSN via the pinch test. you should be able to pinch the fule line and have it run 2-3 seconds there abouts before it shuts off. If it runs longer you are too rich on the LSN give it a 1/8th turn and try again. If it shuts immediately turn it out 1/8th. Then adjust the idle if it needs it after that.
Try gumtree Gold Coast , there is a guy that tunes them cheaply
He has an add on there
