Nitro car in water
M1tanker
So last night I had a run away ofna buggy that went diving into a pond. Could not find it and took a fishing pole out today and hooked him about 5 feet down today after work so he was under for about 20 hours. I got him home to the ER and took him completely apart took the motor apart the diffs are still together haven't messed with them. I took all electronics out took servos apart so they could dry. Here's where I maybe in luck the motor turns fine looks ok. and the servos and receiver I am hoping since it was not getting power will be fine. What do you all recommend to keep it from rusting or to just clean it up. I washed if off with the hose after I got motor and electronics off figured that would not hurt anything but get the and crap off. Any advice?
The engine should be ok if you tear it down completely I mean all the way to pulling the piston and sleeve out of the engine and soak it in WD-40. As for electronics I personally wouldnt risk reusing them. Also your going to want to either pull all of your bearings and clean/relube them or just get a bearing kit from fast eddy and replace all of them.
As for the diffs I would open them up and give them the same WD-40 treatment and then refill them with oil and put some good synthetic axle grease on the ring gear when you reassemble it. I would also rebuild the shocks just to be safe.
Just a question, could you see how long the bubbles came from the exhaust when it sank? Surely it didn't run longer than a second or two before the water cut it off but were you close enough to see where it went in and where you found it?
Don't put the ESC in a bag, it doesn't have one. :rolex:
I wouldn't risk running the throttle servo again, that may cause another runaway. I wouldn't be suprised if your rx is junk too. Everything else should clean up and work fine, no need to replace all the bearings.
There was bubbles in the water for a little bit but I am sure that was more of the tires filling up cause they were so tiny the part that pisses me off I have 5to fail safes and haven't installed one lol
Bet you install one after this happened huh? Sucks that it caused your rig to drown. Good luck with all the salvage and saving engine from rust.
