M Shark
First and foremost, this is my first RC car ever. I am a total noob with RC cars but I have been turning wrenches on real cars for years.
I have a Savage X 4.6 that I just started the break in process. I have used a total of 6 tanks so far for the break in. 2 Tanks for the warm up, 2 tanks for the first run, 1 tank for the 2nd run and so far 1 tank used during the tuning process.
Everything seemed to go well until I hit the throttle a little and saw debris flying off from the truck.
I immediately checked it out and the first thing I noticed was that the spur gear was completely off the transmission. The teeth of the spur gear did not seem worn out but the back of the spur gear looked burnt. The slipper pad was missing about half a piece, looked black and appeared to have melted onto the back of the spur gear.
Any ideas what might have happened?
For your info, I use 30% Nitro fuel. I also had a hard time starting the truck initially so I leaned out the HSN maybe about (3 ) 1/8 turns and increased the idle about 1/2 turn coz the truck would die on me and conk out when idling.
My questions:
1. What caused the meltdown?
2. Should I upgrade the spur gear?
3. Any other comments and advice much appreciated.
Thanks in advance! From a noob!
---------- Post added at 10:30 PM ---------- Previous post was at 10:26 PM ----------
The highest temperature reading I got from an external temperature gauge was about only 215 degrees. Most of the time it ranged from 140-180 degrees.
My questions:
