Sold / Found NEW RX battery packs Hump and Flat
Status
Not open for further replies.
FastEddy
The Slowest Guy In Town
RCTalk Vendor
El Dorado Hills, CA
3 New (3/2 Hump) 1100 mAh 5 cell 6v packs with universal plug.
1 New (Flat) 1100 mAh 5 cell 6v packs with Losi / Xray plug.
All packs are $19.99 plus $3.85 USP Priority Mail
All batteries are sorted (matched) according to internal resistance, capacity, and average voltage. Batteries with the same physical properties are assembled into battery packs. Units are properly hand soldered not spot welded. Each battery pack is individually cycled 2 times to ensure the highest quality.
30 day guarantee (Swap)
are you planning to do the high current flat packs anytime soon?? w/ the universal connectors?
Just so happens......
These are high discharge 20C cells.
They are great for bashing and will most likely hold up well for racing . I'm holding off advertising them as such because I want to compare them with a different brand that I'm getting later next month to see which has a better curve.
I want to offer only the best available to people. If you give me the draw your interested in I will print the curve out and let you make up your own mind.
I can build any configuration you want. 5-6 cell.
Ed I know I talked to you about the packs but do you have any for a Mini T? The ones they sell in Rechargeable form is a 7.2V 1100Mah pack. It seems that the Mini sucks with that pack. I also want to get one for the X5 soon. What is the highest Mah Rating you have for a Savage pack?
Rides that need one.
Savage
Mini T
X5.
Bump for a straight up member!
Jon
Is the 6-cell pack 7.2 volts? What kind of servos run on 7.2 volts??? Like Jon2 stated, what is the highest Mah rating availible? I may want to get an extra pack for both rc's...
Right now I'm using 1100 2/3As for my packs.
I'm only doing RX packs at the moment. As soon as the new shipment comes in I will offer Packs for the 1/18th scale cars and trucks.
For the most part a 6 cell or 7.2 volt battery pack is for use as a main battery in the 1/18th scale RCs. I wouldn't recommend using them for your RX. You can but they usually don't fit in the battery boxes.
Is it possible to make a 2700Mah rx pack? I have one on my maxx... i have a 2300mah on my gt.. j/w...
Ed knows his stuff on these packs. I am definitely getting a pack for the savage and when ver I get a damn Engine I will get one for the X5. I have a pack that I am more than likely going to sell. 2500 Mah pack for the x5 that uses AA cells. Big as hell.
Ryan with savage said:
It means I had a childish snigger at "bump for a straight up member"....
OOOOOO. Just wondering what it meant.
Now buy a pack from ED!!!!!
Is it possible to make a pack for an Airtronics MX-3? JW, cuz I was thinking that only specially made packs (specially fit) would fit in specific radios. I'm probably wrong tho.
A pack can be made for any radio. Its a matter of the connectors used. I have no clue what that radio uses. If you take a photo of it I can take a look.
I would, but i was just wondering. I need to save my money right now... thanks for the info.
Eddy ..
Can you make themlike the trinity ones .. 4 on bottom and one on top?
OK here ya go
Status
