new revo owner some questions??
rckid91
what does the center diff do and does it eliminate my reverse??
the rear brake kit is it worth it?? and what chassie modifications are needed?
also wats a good wieght oil for the shocks on a dirt track
The center diff will eliminate your reverse. It comes with a forward only conversion built in. The center diff transfers power from rear to the front wheels giving you better acceleration and turning. The rear break is only for the center diff and is a must if u have a center diff because if u don't have it the rear wheels will not stop only the front wheels will causing you to lose control. For oil weights in the front and rear diff cases about 30-50k and for center diff 500k.
Yea what he said.
I have one revo with the center diff & 500K.it comes with 100K.With 100k in there the front wheels turn into pizza cutters real fast.500k seems to be good an occasional controlled wheelie on rough sections or uphill but the front tires don't turn into frisbees.
The other no center diff and I use the wing as a wheelie bar.
I need some track time to see what works for me and what is faster but so far I can say the center diff makes in a little easier to control but without it it locks a grin on your face.
I was considering pack the center with Offna diff lock or Bad Horsie diff lock to see if it was stiffer than 500k. What do you guys think?
diff lock
yeah.... I bulit a totally new rear diff and keep it off the truck unless I am gonna be in dirt... locked rear diff + sticky surfaces = many broken parts!
I'm guessing that with the posi-track rear end.. it is more likely to flip now? cause i would like to get that for my REVO when i get it....Also, what is a good company that would sell a 73-87 Chevrolet body for it? I've got an '83 that i restored and i thought it'd be cool to paint the rc truck just like my actual truck
What does the center diff do and does it eliminate my reverse??
The center diff on a Revo does 2 things..well actually 3..
First..Why Have Differentials
Hopefully it's no surprise why we have differentials, but if you were just born here's a quick explanation: During a turn the inside wheel travels a shorter distance, and therefore can spin at a slower speed than the outside wheel, which has to go farther. Since both are on the same car, it would be difficult for that to happen without the invention of the differential. A diff allows one wheel to spin faster than the other, which improves handling in corners. In four-wheel-drive vehicles a third diff is used in the center, to allow the front and rear wheels to travel at different speeds as well.
Without any friction with the ground, the system would transfer power to the wheel with the least resistance, and result in a loss of speed in a corner and over bumps. We've all seen Subaru commercials explaining that having power to the wheels that grip (have the most resistance) improves handling. The way that is controlled in RC vehicles is with silicone diff fluid (and in some cars thick grease). This acts as a "limited slip" differential, and allows the wheels to spin at different speeds - but maintain power delivery to the wheels with more traction. The thicker the oil, the closer to a solid axle the diff acts, and the thinner the closer to an open differential it is.
It is by controlling the diffs with fluid viscosity that we alter the handling characteristics of a car for faster acceleration or more steering.
The second thing that the center diff does is eliminates reverse in a revo. The last thing that the center diff does is allows you to install the rear brake.
The rear brake kit is it worth it?? and what chassis modifications are needed?
If you Race the answer to that question is YES..the brake kit is pretty much a "must have" it allows you to adjust brake basis (I have mine set at 40% front 60% rear) and this aids in how well you can turn and it lets you carry a lot more speed into a corner by allowing you to brake much later and still have control over your steering. If you have the 3.3 chassis no mods are needed to install the brake kit..If your planing to race the 3.3 chassis is also a must have, so if I was going to install the center diff and the rear brake kit and I had the 2.5 (shorter) chassis I would change the chassis also. But if you have 2.5 chassis you do need to cut the chassis so the brake calipers fit, They do include instructions on how to do the modification.
Also what's a good weight oil for the shocks on a dirt track..
I have a base line set up (Steve Slayden's) that works for most tracks.. For shock Oil:
Front: 60wt. #1 piston, Gold springs.
Rear: 60wt. #2 piston, Tan springs.
I also set my shock length to 96mm (end to end).
Sorry for the long post..just trying to help..:yes:..I hope this helps..
how do you set shock length??
and yeah man it explains alot
Their are a few different ways, One of them is to set it by how much you tighten (screw in) the shock ends. The other way is to use spacers inside the shocks to limit the down travel. The shock ends are the easiest way to adjust. One other thing that I did on my Revo is I went with the Aluminum Shock Ends, their are a few different companies that make them. I had found that the heat from the pipe made the rear shock ends brittle..as in they break after a while. It's a cheap fix for what could be a future problem.
yeah thanks for all the help man i just rebuild my shocks with stock front pistonsin the rear and the #3 pison in the front seems to be a little soft i have long travel rockers and arms but i have a feeling 35 wt dont cut it
Not for big jumps..
yeah well the jump on my track is a four footer so???
