yes and no. due to the black needle having a more sqaured off shape, the high end needle tends to be set more lean before the low speed can be set correctly. this is becuase when the black needle fully leaves the seat at WOT, there is a sudden surge of fuel coming into the engine. the silver needle is more tapered and fuel comes in more progressivly. and so to rid get of the bog that may occur during mid to high transition the high end is set slightly leaner than you would with the silver needle.
so overall you will have a slightly leaner mixter when dailed in with the black needle and have more overall power. this is jsut IMO, but i really feel the engine makes more crisp power thru out the power-band when dialed in with the black needle.
BTW i recently added one .10mm shim and am using OS A5 plugs with trinity 30%, with the shim tuning is even more consistant with very raw power at around 230*, actually i cannot notice (if any) power loss.
