yea. well than i aprove :thumbup: *ding* i gess when you took the shot you couldn't look right into them hu. Well nice. Did you modify a kit or you made every thing. If you changed the LED's you might want to change the voltage. Remember V=IR voltage(v)=current(a)resitance(ohms)
if you have let's say two 2.5 lights in a sirries and it is hooked up to a nine volt battery than the voltage=5 (9-(2.5*2)) and it is a 30 ma (0.03). Then the resistor is 5/.03= you need about a 167 ohm resistor.
If it is in parrel then the curent goes up not the volts. So lets say it some how was a 5 volt led. with a current of 70 ma. you have 5 in parrele
5*70=350ma or .35ma voltage=4 (9-5)
4/.35=11.5 ohm resistor. Got it.
rember solve for r.
So good job there man. It does look nice.
I was kiding in my erler post.
now when i build my kit, did you use LED mount or an apoxy or adhesive of some sort?
