craig911
my engine is a HPI F4.6 my spare`s engine is a ansmann AR .28
ok i made a thread a couple of days ago showing what happened
https://www.rcnitrotalk.com/forum/showthread.php?t=99344
well on sunday i picked up my spare engine that i was going to use from a friend ( no dice had a nice hole in crank case ) but other than that the parts were perfect,
well after stripping the spare engine down as it was used only 5 times i noticed the crank shaft was a perfect fit ( identical to the one in my HPI engine ) so i took out the broken one from my F4.6 and fitted the downer crankshaft, it fitted perfectly,
after replacing the crank shaft i can't start the engine everything is moving freely and smoothly my tune is set back to stock but still no dice,
today i switched the piston sleeve as it was in perfect condition as said only ran 5 times and well it was time to replace it and it still would not start altho i do have better compression with the downer sleeve,
i know some of you will say what do i expect the downer engine is from a different manufacturer but like i said the parts are identical,
my glow charger is fully charged i checked it with all my plugs and there glowing as they should, its the same symptoms as when my clutch springs were 2 soft it seems to want to start but wont i even tried with the clutch bell off and still no go,
also how do i remove the bearings from a crank case,
and I'm thinking of changing from a .28 to a .21 for longer run time what would be good to run a ansmann kryptonite
