Neutrual ??????????????
I Pressed A Button On My Aftershock It Said C On The Button And When I Started It Up It Wouldnt Move Neutral Or Not ???????
Are you talking about a button on your transmitter? Or on the truck itself?
Read your manual. I believe you have an XR2i. That is normally for the reverse unless you changed it and causing it to not work. Its considered the reverse or the 3rd channel.
The XR2i is 2 channel remote. No reverse or third channel function.
Grip button C is used to override the steering dual rate set by grip button B. Example if you have your dual rate set to 50% but need 100% during an accident situation, you can assign grip button C to override the 50% dual rate. Or you can set up grip button C to not do anything at all. Look at page 15 of your manual to assign function to grip button C.
www.rcdocuments.com
Yes you are correct SD. Meant no confusion on the "third channel' I must have been thinking of my old MGT. I used an XS3 that had the "third channel". The XR2i is a fairly simple radio. I think I had one for my old XXXnT, great radio to star off with and is better than most AM radios that come in RTR's.
Have you checked to see that the servo is trying to open the carburator?
