demonio
Having some trouble starting my baja. Any help/advice would be greatly appreciated!
Bought an used Baja 5b SS with an almost new cy290, race ported by ESP (big bore 36mm kit if it helps at all)
It started on the second pull the first time, used it for about 2 hours without a single problem.
Next day ran for about 15 min without a problem, then suddenly it started making a weird noise (as if about to run out of gas kinda noise) it speed up and started moving forward for about 30 secs and died, could never get it started again after that. (yes it has gas, yes it's mixed properly)
Sounds to me like its a fuel problem, but I took the spark plug and dipped it in the gas tank and its still not firing up. I have tried 3 new spark plugs as well, tested them outside and they have good spark.
Is there anything else I can try without removing the carb/engine?
Thanks
EDIT: I ran it on a field of dried grass, and it was everywhere, I noticed the pipe had started to melt the part of the cage it sits on, could I have damaged something if it overheated?
Thanks
