OK, I'm starting to assemble the clutch on my 4.6. When I put the clutch nut on, the groove doesn't line up with the clutch springs. The nut has one flat side and one conical side. I assumed that it should be mounted with the flat side toward the flywheel. But that puts the groove for the clutch springs well below the springs. Should the nut be installed with the conical side toward the flywheel? The manual shows a different nut and isn't very clear on it.
