need help with two speed adjusment
WazabiQc
Quebec
Hey guys, i'm trying to set up my shifting point, however by following this guide ( http://traxxas.com/support/2-Speed-Shift-Point-Adjustment-0 ) which is the exact same i have in my owner's manual, i can't gfigure out which screw is the right one ! it says the first one i see by turning counter clockwise is the one holding the whole system, and the second one is the adjustment. then there's a pic or those screws, and the one that i see first is the one that is angled a bit, which seems to be the adjustment, and the second one goes straight to the center. which one is the good one ?
Buddy, you already have it figured out. The one going straight is the one that tightens the clutch to the shaft. The one on the angle is the spring tension adjustment for the clutch. Loosening the screw will make it shift sooner at a lower RPM, tightening it will delay shifting to a higher RPM. Do it in small adjustments because usually, a little means a lot. Maybe 1/8 turn at a time.
Thanks! I rather ask than break something. Their guide is silly when it comes to find the right screw haha.
