Need help with Ofna .26 tuning
only-half-evil
Gone - bye bye.
Pennsyltucky
A buddy of mine gave me his Ofna Picca .26 to put into my T-Maxx. Got everything to fit with no problems...down to the EZstart. Everything works...but the carb on it is so out of tune that its crazy. Looked up the factory settings...and they just don't seem right. 10 to 11 turns out on the LSN...that can't be right. Can anyone give me a good place to start...how many turns on the HSN, LSN and the idle? If I can get into the ballpark, I can get it from there. I just don't wanna treat it like my TRX 2.5 and end up ruining it.
How did you get the linkage to work with the OFNA carb? Have one of the carbs and the linkage adjust all the way out and hits the spur gear.
All I did was raise the carb a slight bit, put the carb on a slight angle, adjusted the connector out only 1/4 of an inch and played with the push rods. You just gotta play with it...keeping in mind that the Ofna carb is longer. Wide open...its only a hair away from the spur gear...but a hair is just enough to make it work.
---------- Post added at 6:24 AM ---------- Previous post was at 6:12 AM ----------
Don't know if they will help, but I just uploaded some pics of mine. Can't figure out how to attach them to this (cuz I'm using my phone instead of computr), so check out my albums.
---------- Post added at 6:29 AM ---------- Previous post was at 6:24 AM ----------
And thanks, Snook Man. That's exactly what I needed.
Is it a Picco Max.26 or Picco Outlaw .26. 2 entirely different engines. The 10 turns out is for the big block Outlaw version.
