Need help tuning!
sad_rocc
Pt. 1
I'm fairly new to tuning engines with a hi and low speed needle. For my stock SH .21 motor (from a PRP Swift 1/8 buggy), the low speed is the screw in the bronze casing and the hi-speed is the one at the end of the slide carb right?
Right now, I have a decent stream of smoke with a little fuel spray at idle, but when I hit the throttle it just chokes and dies. I assume this means my idle is good but the hi-speed needle is way too rich. Am I right?
Pt. 2
I got it so at idle it's burning just before it starts smoking. As soon as I hit the gas, I get tons of smoke and the engine screams. If I let off the gas though, even a tiny bit, it dies. Sometimes at low speeds it will hiccup and die when I'm holding the speed low and constant. What am I doing wrong?
You've got it backwards. The lsn is where the slide is on the carb, and the hsn sticks up where your airfilter ties on. I'd say that your a tad rich on the bottom and way too lean up top.
Try just tuning the hsn counter clockwise 1/2 turn then try it, then go 1/8 turn either way to get it just right.
Ah, yeah that would be a bit of a problem! Since I was wrong on this, I just want to double-check. For both needles, richening is when you turn them counter-clockwise and leaning is clockwise correct?
Correct, also do some high speed runs and get your HSN tuned first then go back and tweak your LSN until you get good performance off the line.
