Damn Skip you have changes the whole layout of that rig. I see you have moved your electronis to allow the Mid tank mod. Pretty trick! I am sure there are others that are interested in your mods. Can you post any info up for our members?
you can fix it with a soldering gun and some plastic from the splash guard.
just check it when your done for leaks i have done it to many tanks at the track when i was in a bind, if pics arent descriptive enough jsut ask and ill explain what to do
here is somethign to do so ur tank doesn't wobble as much and helps it from cracking when smaking the tvps off jumps also:
