Need help ASAP!!
Zachary
Gone - bye bye.
Okay well Friday morning I'm leaving with the family on vacation and am really wanting to take my savy with me. today i filled it up and tuned it since i got my temp gum back and now i don't know whats going on really.
My engine seems to be gurgling when I'm at WOT. It runs fine, no loss in power, nice steady 218* temp and quick off the line. I don't know if it's a bad thing but it just doesn't sound right.
Then also My engine will start up and run until I hit just under 1/2 a tank then it tends to die. It will ideal but if i gas up it dies, yet if i fill it up it runs strong again. I've checked my tank and not holes or anything. Whats going on here?
And lastly When i primmed my engine I would have nitro come out of the side of the carb, the screw on the right in the pictures under the HSN. I put new O-rings on and just screwed it back in. Is there a certain amount of turns it is suppose to be in? also whats the factory settings on the axail .32?
http://www2.gpmd.com/imagel/a/laxig1330.jpg
Thanks a lot in advance,
Zachary
sounds like your to lean and when you reach a half tank your running evern leaner so your truck dies. try richening it up a bit.
this will help you with your half tank lean issue
http://motopsychowebs.com/ftp/Ofna Mod.pdf
as for your carb leaking fuel when you priming your motor. that means you have and air leak which may also contribute to your half tank lean issue.
try doing this to your motor and your should be fine with no more leaks
http://www.savage-central.com/modules.php?file=viewtopic&name=Forums&t=54465
Well fixed everything today by richening the LSN. And i said i put new O rings on and wasn't sure how far the screw was suppose to be put in. but fixed that too.
How is that temp gum working for you? Do you chew it before or after use? What flavor is it? Sounds kinda cool, might have to get me some :p:
loooooooooooooooooooooooooooooooooooooooooooooool Parputt
