Things have gone from bad to worse. My engine is practically new and was running rather well except that it would eventually stall and not want to restart. Now nothing I do will make it keep running. As far as I know it was not run for any amount of time at a real high temperature. I had checked the temp quite often because I bought a new infered gauge. It seems like a carb problem but I just don't know anymore. If I reset the neddles to the factory settings it will not start at all. Fuel spits out the pipe pretty much. If I lean the bottom end about a turn or so I can get it started but only at about 1/4 throttle. It seems to make no difference where I set either needle it will not go to a slow idle and stay running. I cannot find anything loose to cause an air leak. I have tried another manufacture carb and that was about the same or worse. I have never had this kind of problem before. This engine ran good during the breakin and for about the first three or four times I ran the truck then went sour. I have been using an OS #8 plug and tried a McCoy #9 with no difference. I run with O'Donnell 20% fuel. Could it be the fuel, it was just purchased and opened about a week ago (after the problem actually started). I'd appreciate any help, I really can't afford an engine and that approach would park the truck for a long time to come. There has to be some of you out there that haven't switched to Ofna and Picco engines.
Thanks, Larry
Thanks, Larry
