I bought a brand new HPI Savage 4.6 last Thursday. I ran the 2 idle tanks and the 2 easy 1/2 throttle tanks like the manual said. Even at 1/2 throttle during break in it was trying to wheelie. So I went the LHS and bought a wheelie bar and mounted up and went to tune. And then the nightmare started.
It got very hard to start so in running the nitro start drill so much (not continuously but so many 3-4 second bursts) it loosened the 2 small allen screws that keep the nitro start receiver locked onto the OWB shaft. So I took everything apart very very carefully and (not knowing exactly what I was dealing with) had the back plate off. I made sure pin was set in the crank to grab the OWB internally, RTVed the back plate, and reassembled with thread lock. No more issues turning over.
Put a fresh glow plug in it and went back after it. I just cannot get it right. I've tried HSN first. I've tried LSN first like Rolex suggested. It just will not tune right. As it sits now it will take off and shift with smoke out the exhaust but is sluggish until the very last bit of the power band. If I try to lean out anymore it will flame out. At least that's what I believe it's doing. As soon as I let off the throttle and sometimes while I'm running around 1/2 throttle it just dies. No hesitation, no warning, just goes from running to not running instantly. I cannot get the performance back to save my life. No attempts to wheelie, just smooth but slightly sluggish acceleration until it builds enough momentum and then it will haul ass balls to the wall like it should.
Man I really need to find someone close to San Antonio to give me a hands on tutorial or make a friend at the LHS or something. Jeez. Right now if you put a gun to my head and told me to make that Savage run right I would have to take the bullet.
As always, thanks in advance for the advice and help and if there's something stupid I'm missing give me hell about it,
Doyle
Doyle
