sounds too rich to me as well, either that, maybe it was not put away properly and a gasket some where is no good, if those dry up and crack it can cause problems, also, like for me in maine it is cold outside, and just today trying to run the maxx, it would not start, after about a min of being outside the engine was as cold as the air, so i brought it inside, cranked the furnace and put it on a grate to get hot, then when i took it back out, fired right up, it is a two stroke, so if its cold it may not want to start, try leaning the low speed, and check your idle, and like dude said about playing with the throttle, if you ever prime it you only want to do that to get the fuel in the line, after priming for around 2-secs, play with the throttle, usually i would allow mine to worm up for a min feathering the throttle before opening it up, if it floods, witch is what you experience when you prime it too long, pull glow plug, flip it over and with a rag turn it over and get the fuel out, use the rag to avoid getting the fuel that comes out on anything or in your eyes, then try again, some people suggest loosening the glow plug to start it, then tightening it, this i have never done just remember reading that, if you try everything and it still does not start, i would clean everything out, maybe even get new gaskets, sure hope its not blown, if so you can get a piston/sleeve for around 50bucks, you will get it I'm sure
