- IDAHO
- Racing
- Crawling
Well I've kinda drifted away from the car audio world over the last couple years and didnt even do any installs over the winter wich was a part time job for me, so I've decided to put up a couple things for sale. I doubt any one here buys it but I thought Id let yall have a shot...
I hit 144 db's with this setup in a 5.8 cu ft ported to 32 hz box in a non vented to the cab trunk! Thats not the easiest thing to do and this setup proved that is possible with out multiple amps and several subs.
First up is a FI bl 18.
Heres some specs on this beast.
Fs: 33.2 Hz | 33.2 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Cms: 0.88mm/N | 0.88mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 181.0 l | 181.0 l
Spl: 94.1dB 1W/1m | 94.1dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft
heres a pic from a while back.
And either $225 plus shipping for the sub or $250 shipped! Remember this sub is alost 40 lbs!
AMP SOLD!!!! SUB LEFT FOR TODAY!!!
U.S SHIPPING ONLY!!!! PAYPAL ONLY!!!
Qms: 5.82 | 5.82
Qes: .32 | .32
Qts: .30 | .30
Mms: 302g | 302g
Xmax: 18mm | 18mm
