I just bought a Used savage. It came in 3 peices.the center section, rear suspension and front suspension. I assembled it and got it running but it won't go!
I can see the gears moving in the transmission case. I even took the transmission apart to inspect it. It seems like the 2speed clutch is in backward from the way i would expect it to work. However it is installed the way the manual says it goes.
If I spin the spur gear clockwise (the way the motor spins it) the gears in the tranny just free spool. If I turn it counter clockwise (opisite motor) the gears lock. Shouldn't the work the other way?
Any Ideas on what the problem could be?
Thanks,
MIke
Thanks,
MIke
