I just finished breaking in the TMAXX 2.5 and these are my remarks:
What I like!!:
1.) The EZ start is really cool it is so fast to start and your time is longer playing with instead of tinkering with irt
2.) The handling of it really nice. The wide arms make taking turns easy. Of course full throttle turns will make it flip on its lid. I know this cuz I did it three times! still fun.
3.) The suspension is really soft and easily takes the little curb jumps and little air jumps I did. I am sure with the jumps I plan on doing I will probably upgrade to some better shocks.
4.) The power of the 2.5 is pretty impressive. Once I got the tune down to science I was able to oper her up and get her to really show the power. The 2 speed is pretty cool as well. Once it kicks in it really goes. Once again after I get bored I will more than likely change it out to a sirio 18 since it will still work with the EZ start. .
5.) The durablilty of the Tmaxx is still new to me as I have not really done some really good off roading. But as far as I can tell it is ok. I will definitley upgrade to some aluminum braces and some RPM A-arms.
6.) The Brakes
What I do not like!!
1.) The EZ start is cool but if you flood it it is pretty right to get the fuel line off and clear it out. Still do able though.
2.) THe Exhaust outlet position is HORRIBLE! When I pull her into check on it the right rear tire is covered in oil that had exited the exhaust stinger. That is bummer.
3.) The steering of the Tmaxx leaves a lot to be desired as it a really weak servo. I will definitely change that out for a hitec 645 along with the servo saver.
4.) THe Reverse Module sucks! I found the Tmaxx in NEUTRAL since it wouldn't go into Forward for awhile. Maybe someone can help me on that one.
What I like!!:
6.) The Brakes
